Not able to change gears/electrical "Nightmare"
Old Jan 10, 2025 | 05:14 PM
Extinct's Avatar
Originally Posted by Tomzsix
where do you get a relay tester ??
You can test a relay with test leads and a voltmeter.
Old Jan 10, 2025 | 06:54 PM
mollusc's Avatar
Or swap it with a different known-good relay from another slot.
Old Jan 11, 2025 | 06:14 AM
Mando's Avatar
Thanks Extinct, I'll "relay" to my mechanic.....
Old Jan 18, 2025 | 12:07 PM
nashvegas's Avatar
Question: Have you been either:
1) Been messing around with a Nanocom or coding device by chance?
2) Added a 2004 center diff lock to the truck ?
Because -- if you screw up the settings for either the the transfer case in Nanocom, you can get exactly what you described. I know because I did it, had a rapid clicking and couldn't shift into gear.
A few more ideas to pinpoint... these are all things that will cause that rapid clicking from under the dash / steering column area:
1) brake light switch (sounds like you changed that). PS - Also, and it sounds insane but makes sure all of your brake light bulbs are good and working. There is a scenario by which somehow they backfeed current thru the brake light switch and cause all sorts of hell if a filament breaks in just the right way on early D2's.
2) shift interlock (under the shifter there is a switch that prevents you from switching out of P unless brake pedal is depressed)
3) fuse box is corroded from water ingress (fuse box under drivers steering wheel)
4) As above, transfer case interlock settings are set incorrectly from factory settings (ie someone has changed interlock for either gear shifter or transfer case recently in Nanocom, or truck is new to you)
5) XYZ switch under the car is bad - can also cause haywire stuff like this
WNYErikDiscoII
Jan 29, 2019 12:19 PM
Steellifter
Mar 24, 2012 01:38 PM
range_time
Apr 20, 2010 07:56 PM
marcus418
Apr 9, 2009 06:18 PM
95Discovery
Jun 20, 2006 02:56 PM
