OBD recommendations please
Old Jun 4, 2015 | 07:47 PM
LR03NJ's Avatar
Default OBD recommendations please
Im looking to get an OBD. Can anyone give me suggestions? Something reasonably priced. Thanks
Old Jun 4, 2015 | 07:55 PM
abran's Avatar
Ultraguage, reads and clears engine codes, gives live data, and the most important...engine temps.
Old Jun 4, 2015 | 08:00 PM
Scout_Beagle's Avatar
Autel AL619 will read and clear ABS codes as well as handle OBD2 duty ( once you update its software, which is easy).
Old Jun 5, 2015 | 03:24 AM
Fallstaff's Avatar
I just use DashCommand and a cheap Chinese WiFi unit. Seams to give me all I need for peanuts.
Temperature + Codes + Clear Codes. Not sure what else you get with more expensive setups, but does the trick for me.
Old Jun 5, 2015 | 05:19 AM
drowssap's Avatar
the icarsoft obdsII on ebay are around 130 they do abs as well as srs codes
Old Jun 6, 2015 | 07:08 AM
USAroverman's Avatar
Anyone know the least expensive scanner that can also bleed the ABS system?
Old Jun 6, 2015 | 07:49 AM
dusty1's Avatar
cheapest way to do abs too..i think....https://landroverforums.com/forum/di...-vmware-64725/
or an ultragauge and an amigo
Old Jun 6, 2015 | 10:14 AM
drowssap's Avatar
Least espensive, a paper clip across the ABS relay
Rover Newbie
Jun 25, 2014 07:21 PM
san988
Dec 25, 2013 07:25 AM
johnkbl
May 3, 2010 06:19 PM
alemurill
Jul 9, 2008 10:16 AM
humroot
Nov 12, 2007 06:53 PM
