Odd fuel trim behavior .. brake pedal makes drastic change
Old Apr 16, 2019 | 11:19 PM
Ben Matheson's Avatar
Default Odd fuel trim behavior .. brake pedal makes drastic change
My short term trim per UG bounces around from -5 to +5. I noticed while sitting at a light and pumping the brake pedal makes it go up as high as +15.
Normal? No? Kind of an odd scenario and not a normal test but can anyone shed any light?
Old Apr 17, 2019 | 09:25 AM
FlyingZebra34's Avatar
Not sure if it's normal. My engine is all over the garage right now. But possible vacuum leak? Maybe inspect the booster and vacuum lines? They are starting to get older for all of our cars. Does anyone know where to replace the plastic vacuum lines by the way?
Old Apr 17, 2019 | 06:49 PM
Extinct's Avatar
Yes, brake booster indicates you have a vacuum leak somewhere. You can hook up a shop vac to the intake pipe and it will whistle at the leak.
adolfojbonilla
Oct 5, 2019 12:30 PM
boston4
Sep 21, 2019 01:29 AM
adolfojbonilla
Apr 16, 2019 09:17 PM
ctang101
Nov 7, 2017 08:38 AM
me6067
Jun 26, 2015 08:13 PM
