The Official Extinct Inline Thermostat Mod Thread
Old May 25, 2025 | 12:58 PM
  #521
Discoidiot's Avatar
Originally Posted by Extinct
Yes, much too hot! That hot on the highway suggest you have a plugged radiator although it could be a failed thermostat but unlikely. First step is to pull the thermostat element out of the housing completely because at 95° ambient temperatures you don't need any thermostat. Put it back together with no thermostat element in the housing and run it and see if it still gets hot, my guess is it will and that tells me you have a plugged radiator
Swapped the thermostat for a AutoZone Duralast (I didn't even spill any fluid this time, yay me!) and started the truck up. In 5 minutes, at only 70 degrees today, I was back to 230, 240, and creeping home...Radiator was the only thing I hadn't replaced in all this work... The thing is, no weird colors in coolant, when I filled the entire system, I used exactly the proper amount, etc. None of the usual signs of issues...
Old May 26, 2025 | 11:29 AM
  #522
Diesel Gypsy's Avatar
I would still suggest you try Extinct's suggestion of running it with no thermostat at all but I suspect the problem is likely a little deeper.
Radiators don't usually plug up quickly so I'm not sure that is the problem either.
Try to determine if the the pump is circulating coolant. It wouldn't be the first time a water pump impeller failed.
I'd also check the inside of that kinked hose to see if the lining has possibly folded over blocking the flow.
Old May 27, 2025 | 01:21 PM
  #523
Discoidiot's Avatar
Checked the thermostats in a pot of boiling water and they open close normally. Pulled the serpentine belt and the water pump turns nice and smooth. Checked inside the hose and liner and everything is nice and clear and only 3 months old.
Any other items to check before radiator replacement? Looking at the Nissen radiator and Delphi temp sender from Rockauto (best pricing) - anything else to replace/check in doing this swap?
I hate spilling coolant more than anything else...
Old May 27, 2025 | 01:31 PM
  #524
Richard Gallant's Avatar
@Discoidiot Check you hoses are they hard, I am assuming you are not losing coolant. I would start with a new rad they are cheap enough and you get that out of the loop.
Old May 27, 2025 | 02:25 PM
  #525
Discoidiot's Avatar
Thanks Richard - yes, back in January I replaced the entire cooling system - new hoses, water pump, cam sensor, reservoir, etc. Radiator was the only thing I didn't touch.
Old Jun 3, 2025 | 07:27 AM
  #526
Discoidiot's Avatar
Swapped radiator and was so proud for not making any kind of mess.
Unfortunately, temperature is still climbing and nothing seems to have changed.
Any other diagnosis suggestions?
Old Jun 3, 2025 | 12:25 PM
  #527
DiscoMerlin's Avatar
Are you losing coolant? How is compression?
Old Jun 3, 2025 | 12:30 PM
  #528
Discoidiot's Avatar
No loss of coolant, compression is my next check. Valve cover leaks, not horribly, but was going to be part of this summer's maintenance. Water pump was replaced 2 months ago, wouldn't think impeller would fail that quickly and I don't hear any bearing issue when I spin it freely.
Old Jun 3, 2025 | 12:36 PM
  #529
I went through this in the summer of 2023. That is how I discovered this thread. I had no coolant loss, new water pump, hoses, thermostat ( inline), and new radiator. It turned out to be a cracked block.
Old Jun 3, 2025 | 12:42 PM
  #530
Discoidiot's Avatar
That's my fear...
