oh man, not good
Old Oct 14, 2008 | 07:58 AM
discoxd's Avatar
Default RE: oh man, not good
that doesnt sound too hard... but after laying on my back under the truck for thirty minutes yesterday with it running, i dont believe its the seal, i think it is a little sensor on the passenger side, above the front diff.. but very close to the crank seal, thats why i thought thats what it was, its a small white piece with a black electrical clip plugged into it and two wires coming out... is that like a pressured or temperature sensor? i know its a pain in the a** to put a wrench on...
Old Oct 14, 2008 | 08:35 AM
ptschram's Avatar
First off, does no one have a factory service manual?
The oil pan does not have to come off, the FSM even goes into detail about how to repalce the front crank seal without pulling the pan!
There are two sensors on the front cover. The one that points to the side of the truck is your oil pressure switch. It requires a 15/16" wrench to remove, the other faces forward, it's your camshaft position sensor (CmPS) and it is held to the front cover with an 8 m/m bolt. Either one can leak, but if the oil pressure switch is leaking, fix it NOW!
Old Oct 14, 2008 | 09:49 AM
discoxd's Avatar
yeah its the oil pressure switch... 15/16 and the most ridiculous position ever to try and get a wrench on it...
________
WASHINGTON MEDICAL MARIJUANA DISPENSARIES
Old Oct 14, 2008 | 06:33 PM
I had to replace my oil PSI switch too, $13 at AutoZone and a 30 min job because you cant turn the wrench but a 1/4 turn at a time.
Old Oct 14, 2008 | 08:32 PM
discoxd's Avatar
yeah i'm takin the mornin off work tomorrow to go to the dmv and while i'm not workin i will have to swing by the parts store and buy the old xd some gifts...
________
Buy Silver Surfer
Old Oct 21, 2008 | 09:21 AM
discoxd's Avatar
another update... changed my oil pressure switch last night and it fixed the leak, its in a pretty bad spot to get too, but didnt take as long as i had anticipated, i also put in new bosch +4 plugs and bosch premium wires... they're not magnecores but they'll do for now...
________
CALIFORNIA DISPENSARIES
James Vee
Jun 16, 2016 09:00 PM
rick.scott
Jul 4, 2009 12:01 PM
98roverguy
Nov 7, 2006 06:04 PM
05LandRover
ROAMING WITH FRIENDS
Apr 21, 2005 02:08 AM
mikemeyer0
Mar 30, 2005 06:17 PM
