transmission issue...
Old Oct 20, 2008 | 05:03 PM
discoxd's Avatar
Default transmission issue...
my transmission works fine except for one thing... its a 97 d1 with 152000 miles and the issue i have is that if i put it straight in drive, nothing happens, its like its in neutral, but if i shift it into first gear, it will work and then after i take off i can just put it in drive... once i slow back down and it goes to shift back into first at say a stop sign for example, it goes back to neutral... i have been told it is probably just a solenoid... easy enough, but where is this particular solenoid located... i have downloaded the rave manual but have not had a chance to put it on cd so i could view it... i will try to do that today, but if anyone knows off-hand where its located that would be great, or if you feel its a bigger issue feel free to let me know... thanks
________
COLORADO DISPENSARIES
Old Oct 20, 2008 | 05:36 PM
Default RE: transmission issue...
Have you checked the fluid level?
I do not know of any solinods on a DI tranny. Doesnt mean they are not there, I just dont know of any.
Old Oct 20, 2008 | 06:33 PM
Adz's Avatar
Adz
Sounds like a one way clutch has failed... not a relay unfortunately and you're looking at a rebuild
Old Oct 20, 2008 | 06:35 PM
Adz's Avatar
Adz
Oh... wait a sec - have a look here:
http://www.ashcrofttransmissions.co.uk/faq.html#a3
Could be the sprag clutch apparently... To fix it is a rebuild, but it's a 'non damaging' fault if you continue to drive it as it is.
Cheers,
Old Oct 20, 2008 | 07:39 PM
Before you do anything drastic, check the fluid level/condition. Is it bright pink? Doest it smell burnt? Does it feel gritty when you rub it between your fingres?
Old Oct 21, 2008 | 08:08 AM
discoxd's Avatar
i just checked the fluid day before yesterday, no its not like pepto, so no water in it, and it didnt smell burnt, i guess i will juast take it easy on it until i can afford the rebuild...
________
Cellin
Old Oct 21, 2008 | 08:19 AM
Well, now it is time to take it to a tranny shop and ask a few questions, let us know what you find.
Old Oct 21, 2008 | 08:20 AM
Before you rush into a new tranny change the fluid in yours first. It is very easy to do, they even included a drain plug for you.
Go buy 6 quarts of DexronIII, get the High Miles stuff, drain out the old, refill with the new.
It wont take 6 quarts, but better to have more on hand than you need.
After 500 to 1000 miles change it again.
If there is no improvment then you are out $20 and a hour of your time.
Old Oct 21, 2008 | 09:47 AM
discoxd's Avatar
its a really good thing i enjoy workin on cars...
________
Live Sex Webshows
calirover
Freelander
Sep 30, 2008 06:18 PM
summerfld
Apr 26, 2008 11:51 AM
Maximuse34
Jan 1, 2008 03:35 PM
01discosteve
Sep 17, 2007 05:33 AM
superderek3
Dec 18, 2006 12:09 PM
