Oil cooler leak
You have to push forward on the hose while pulling rearward on the plastic quick disconnect release, then pull the hose off. Did you disconnect it during the new engine install? If so, it might not be seated completely which is common. Pull hard on it rearward to make sure it is seated fully and if it comes off that was the issue. Push it back on and the repeat the pull hard test.
