Oil cooler leak
Old Jan 8, 2022 | 01:35 PM
The Ocho's Avatar
Default Oil cooler leak
I have a leak on my oil cooler on the passenger side hose.
how do I fix this? The search feature isn’t being helpful right now.
Old Jan 8, 2022 | 06:28 PM
Extinct's Avatar
Need a bit more history? How long have you had it? When did it start leaking? Recent repairs? Where is it leaking exactly? There is an o-ring seal where it snaps in to the radiator.
Old Jan 8, 2022 | 07:21 PM
The Ocho's Avatar
-I had it for 4 years.
-Just put a new 4.6 engine in it.
-It’s leaking from the fitting from the oil cooler to the hose.
I’m 95% certain the o-ring from the hose to the cooler has given out.
So where do I get this o-ring.
And how do I get the hose off to change it?
Old Jan 8, 2022 | 08:28 PM
Extinct's Avatar
You have to push forward on the hose while pulling rearward on the plastic quick disconnect release, then pull the hose off. Did you disconnect it during the new engine install? If so, it might not be seated completely which is common. Pull hard on it rearward to make sure it is seated fully and if it comes off that was the issue. Push it back on and the repeat the pull hard test.
Old Jan 9, 2022 | 02:37 PM
The Ocho's Avatar
Any idea where to find the oil o-ring?
Old Jan 9, 2022 | 04:57 PM
Extinct's Avatar
Ace hardware, auto parts store. Just needs to be close, not exact.
merebel
Sep 29, 2020 06:32 AM
Beaulim
May 2, 2014 08:03 PM
BoJangles
Apr 21, 2014 03:12 AM
atancreti
Jul 13, 2011 10:20 PM
adowgiert
Nov 26, 2005 01:07 PM
