Oil drain plug washer
Old Oct 19, 2011 | 04:14 PM
buick215's Avatar
Default Oil drain plug washer
I would like to know if you guys change the oil drain plug washer when you change the oil on your trucks or simply use the same one again.
Old Oct 19, 2011 | 04:27 PM
willrok13's Avatar
Not every time. I ordered a bag of them from AB and replace it every three or four changes.
Old Oct 19, 2011 | 04:52 PM
G Reeves's Avatar
every time for peace of mine and for the cost them its not worth bothering about
Old Oct 19, 2011 | 05:00 PM
My truck has the original washer from when it came from the factory, all you have to do is turn it over everytime you remove the plug and it will never leak.
Old Oct 19, 2011 | 05:46 PM
Mine also has the original washer and no it does not leak, from there.
Old Oct 19, 2011 | 08:04 PM
boris_gti's Avatar
I just ordered the bag from Atlantic British and changed for the first time in years.
Old Oct 19, 2011 | 08:25 PM
collin Barrows's Avatar
I 2nd that!
Old Jan 7, 2012 | 12:00 PM
far4cges's Avatar
Searched and found my answer… thanks all!
Old Jan 7, 2012 | 03:00 PM
jeffh's Avatar
wait you can change that...huh.
Old Jan 7, 2012 | 04:25 PM
jafir's Avatar
This is the correct answer. Especially with an aluminum oil pan, you want a new washer so it crushes instead of you pulling the threads on the pan. It's cheap and easy.
Colorado David
Jun 15, 2021 12:31 AM
real_tea
Feb 15, 2013 10:00 AM
krazzz
Jan 15, 2010 07:17 AM
hendoc3
Jul 20, 2007 03:44 PM
DiscoStu
Jul 12, 2007 04:16 PM
