Oil Filter cover
Old Feb 17, 2010 | 02:18 PM
hag1128's Avatar
Default Oil Filter cover
Wife has had no complaints with the 03 disco all winter, thanks to all for the productive reading....
I was changing the oil this past weekend and wondered if there was a black plastic cover on the under skirting that should be in the hole where I reach up to get to the oil filter, something to protect it from the road elements. Looks like it might be a round piece with 3 or 4 tabs on it to hold it in place. Am I correct? Anyone have a Part number, I'm sure its a dealer item.
Off to read about aftermarket oil temp/pressure units.
Randy
Old Feb 17, 2010 | 02:49 PM
lipadj46's Avatar
Most of us who do work on our own trucks throw away the entire plastic bottom panel
Old Feb 17, 2010 | 02:52 PM
hilltoppersx's Avatar
yes there is a piece of plastic there. not sure the part number if you go to the dealer i'm sure they can ID it. i could have given you mine, i took it off and threw it out.
Old Feb 19, 2010 | 05:31 AM
aldredheron's Avatar
4th Gear
I have the OR package with the skid plate that has the small access plate. I went to Home Depot and got stainless phillips head screws of the type that has the tapered heads. The tapered heads fit perfectly in the countersinks on the plate. It has been along time, but I think they are M6. I spray the screws with WD40 every time I put them back and have not had any further problems.
03blackdiscose
Jan 4, 2015 02:17 PM
Kswin
Apr 11, 2010 06:56 PM
brw1982
Mar 15, 2008 02:33 PM
Zonk872
Jul 18, 2007 03:18 PM
