Oil Light On, Ticking Sound, Loss of Power
Old Nov 13, 2008 | 09:11 AM
Default RE: Oil Light On, Ticking Sound, Loss of Power
ORIGINAL: apcollin
did a mix of synthetic/nonsynthetic get in there?
This will have no bearing on how an engine runs.
Old Nov 13, 2008 | 09:16 AM
If your oil light is coming on, then get off the coolant issue and go have your oil pressure tested, cold at idle, cold at 2000 rpms, warm at idle and warm at 2000 rpms. This will mean leaving it in a shop over night.
Get back to us with their findings.
Old Nov 17, 2008 | 05:15 PM
dholland's Avatar
It is in the shop now. They are going to try and see where I am leaking any oil from. They are going to pressure wash the bottom side of my Disco and see what they can find.
Been there since Friday. Hopefully will hear back in a day or so.
Old Dec 20, 2008 | 07:32 AM
dholland's Avatar
Update on this thread...I took a couple of weeks off from here. Because I had to have my engine replaced.
I have found, DO NOT LET YOUR ENGINE RUN OUT OF COOLANT!
If your oil light is on, GET IT TAKEN CARE OF ASAP
I think my engine running out of coolant and overheating caused other problems. After this happened my oil light started coming on. When the oil light was on I had a slight ticking. The slight ticking QUICKLY became a knocking and the car wasn't drivable.
Luckily I was able to get the engine replaced cheaply...I got lucky on this one.
I now keep a constant eye on my temp gauge and am always watching my oil light
Old Dec 20, 2008 | 09:37 AM
That is a hard lesson, sorry to hear about that and I hope others pay attention for their own benefit.
Old Dec 20, 2008 | 12:24 PM
sloppyjoe's Avatar
after reading this just now i went out in my sweats in the 20 degree cold to check my levels on everything. coolant looked to be a tad low but i am also parked backwards on a semi steep slope. i have a bottle of water wetter i was gonna toss in anyways. oil is right at the level max mark. knock on wood,,,
Old Dec 20, 2008 | 06:44 PM
I chack all of my under the hood juices once a week.
Old Dec 20, 2008 | 06:48 PM
sloppyjoe's Avatar
ORIGINAL: Spike555
i check em at every fill up, but this just got to rattling my cage a bit
Humdinger
Oct 18, 2016 05:05 PM
leadfoot
Mar 8, 2014 10:46 PM
john65b
Oct 10, 2013 05:00 PM
mvjimenez
Jun 12, 2010 10:25 AM
ontheroadagain
Mar 27, 2008 08:10 PM
