Oil Pressure
Old Jul 23, 2014 | 12:20 PM
Francopacks's Avatar
Default Oil Pressure
Does 53psi at cold idle seem a bit high? 2,200 rpm goes to about 59psi when cold.
Once it warms up (coolant at 196F), the pressure goes down to about 33psi at idle and 52psi at 2,200rpm.
Old Jul 23, 2014 | 12:36 PM
Jared9220's Avatar
when I first start up in the morning I'm around 58-60 PSI. After it gets to 194 I am around 30-35psi and 52psi @ 2200rpm. The lowest I go at idle on hot days stopped in traffic is 18psi and @ 2200rpm I stay around 52psi.
So, yes those numbers seem completely normal to me.
Old Jul 23, 2014 | 12:54 PM
Excellent. I just finished rebuliding the front cover, so wanted to be sure. Including putting in a pressure gauge following you post (so thanks for that!)
Old Jul 23, 2014 | 01:32 PM
Jared9220's Avatar
Nice! Did you install new oil pump gears? Were your old ones cracked?
Old Jul 23, 2014 | 02:29 PM
5kcstq's Avatar
Yes, normal for me after recently replacing the broken oil pump on my 03 Disco. Glad to have that oil pressure
Old Jul 23, 2014 | 03:06 PM
Mine looked real good and were within spec (according to the rebuild manual). My gasket was leaking coolant into the oil pan.
eaglewing
Apr 16, 2011 11:06 AM
Snafu / Disco Fries
Feb 24, 2011 09:10 PM
lipadj46
Oct 17, 2010 06:34 PM
tito5590805
Oct 4, 2010 09:11 AM
DooDer
Jan 12, 2010 10:46 PM
