Oil Pressure gauge instal
Old Nov 20, 2011 | 07:31 AM
anbran's Avatar
Default Oil Pressure gauge instal
I would like to instal my new gauge (Glowshift) and I am not sure which fuse locations I can put the 3amp fuse adapters...I know there was a good bunch of photos by some fella on one of these forums...but I can't tell which fuse spots he used...
Any ideas?!
2002 Disco
Thanks
Old Nov 20, 2011 | 10:45 AM
willrok13's Avatar
If you're using a fuse tap you can use any circuit that is keyed or switched. I used the headlight fuse for the dimmer function on the gauge, and the aux power circuit for power. That way the gauge turns off when the key is off, and dims when the headlights are turned on. Just check your owners manual for the fuse numbers.
CandiMan
Engine & Internal
Jun 11, 2014 09:18 AM
atancreti
Oct 3, 2011 04:44 PM
lipadj46
Oct 17, 2010 06:34 PM
mordor110
Dec 9, 2007 11:04 PM
Fonzie
Oct 15, 2007 01:47 PM
