Oil pressure great - Then nothing, then great
Old Mar 2, 2021 | 11:10 AM
  #21
redwhitekat's Avatar
rock auto has them $313.00 canadian
SKPSK115084{#LJR000220}Info
Old Mar 2, 2021 | 01:00 PM
  #22
dswilly's Avatar
K & N. Not the big one but the normal one spec'd for the D2
Old Mar 2, 2021 | 01:02 PM
  #23
dswilly's Avatar
I see that now on RA. Funny it did not show on my first search. I wonder if there is a quality difference on these things.
Old Mar 2, 2021 | 03:21 PM
  #24
Best4x4's Avatar
Yeah I looked on Rock Auto before I posted my reply. They're 246.79 USD and show in stock. They also list oil pump kit for 31.79 which is the new oil pump gears and gaskets.
I personally haven't had an oil pump die on any of my LR's. I think it comes down to oil change schedule & oil used.
Old Mar 6, 2021 | 04:48 PM
  #25
dswilly's Avatar
So got in to this today. All went well except for the fan bolt, that thing was a bear. Once I got to the oil pump I was disappointed that it was not broken. Would have been easier to point blame if it was. I did notice some scoring on the housing. Does this look bad enough cause a problem?
The last photo is of a small bushing that showed up in a plastic bin I was cleaning parts in . The parts that went into the bin were the oil pan, front cover, water pump and pick up tube. Anyone recognize this?
Old Mar 6, 2021 | 04:55 PM
  #26
Extinct's Avatar
That bushing came from the valve cover gasket, found its way to the oil pan. The scoring is not your problem. How did the pickup tube o-ring look? What about the pickup screen?
Old Mar 6, 2021 | 09:20 PM
  #27
dswilly's Avatar
Good to know on the bushing, whew. So the scoring does not look bad? The o ring do not look great and appeared to be covered in RTV like someone either tried to mend it or added it as extra precaution. The screen has some stuff but is not sludge filled. So should reuse this cover with the new oil pump or put it back together as it was?
Old Mar 7, 2021 | 06:36 AM
  #28
zski128's Avatar
Did you inspect the bypass valve in the cover? Dont forget to pack the oil pump gears with vasoline to avoid a dry start.
Old Mar 7, 2021 | 06:37 AM
  #29
The Deputy's Avatar
Personally, l'd not reuse that cover...and l'd be pulling a rod cap to inspect bearing.
greisinb
Aug 10, 2020 07:41 PM
FreeRideSLR
Dec 3, 2013 10:10 AM
gbob
Jul 7, 2013 11:25 AM
Zonk872
Sep 28, 2011 10:38 AM
tito5590805
Oct 4, 2010 09:11 AM
