Tricks to securing the crankshaft for flywheel removal?
Old Mar 7, 2021 | 04:59 PM
greisinb's Avatar
Default Tricks to securing the crankshaft for flywheel removal?
OK, here’s where I’m at, my 4.0 block is on the stand and the heads and pistons are out. I need to remove the flywheel to take the crankshaft out but to remove the bolts I need to stop the crankshaft from spinning when I apply a force to bolt. Any tips or tricks? I’m thinking about putting a block of wood down the cylinder bores to brace the crank as I crack the bolts loose- anyone see any serious problems with that?
Old Mar 7, 2021 | 05:38 PM
The Deputy's Avatar
Yeah, just wedge a block of wood against lobe of crank shaft and the block.
Old Mar 7, 2021 | 09:14 PM
greisinb's Avatar
Sounds good...glad for a simple solution! Thanks!
jamestfl
Jan 31, 2017 09:40 PM
walkingzach
Jul 29, 2014 11:00 AM
Brent Miles
Feb 18, 2011 08:36 AM
00&04 Disco
Aug 18, 2010 08:30 PM
tornado_735
Nov 23, 2009 03:09 AM
