oil pressure question
Old Mar 27, 2014 | 01:22 PM
Dave03S's Avatar
Just to update I did an "oil pump" search here, you must use quotes or it won't use oil as a keyword.
The chamfer was only on the OEM factory oil pump gears, aftermarket pumps apparently did not have that and can go in either way.
The best info on oil pumps is found in this thread:
https://landroverforums.com/forum/di...p-51602/page4/
Old Mar 27, 2014 | 01:34 PM
wkburns's Avatar
Thanks guys! I am going to give it a try and put in the replacement parts I have.
Old Mar 27, 2014 | 01:36 PM
wkburns's Avatar
I will keep you updated to what happens as well.
Old Mar 28, 2014 | 09:50 AM
RoverMasterTech's Avatar
See my post about the main and rod bearing replacement. You will net negligible results with only replacing the oil pump gears.
Old Mar 28, 2014 | 10:15 AM
Dave03S's Avatar
Could well be true, however given the choices the oil pump is the logical first place to look. He has no need to replace his "new" set of oil pump rings if they check out ok.
Then he can move on the the bigger harder things like you mention, RMT.
No need changing out bearings if you overlook a broken oil pump. :-)
Old Mar 28, 2014 | 11:14 AM
Car has 150k on it. His oil pressure light has been on and off. What do you think his bearings look like?
Old Mar 28, 2014 | 11:54 AM
Dave03S's Avatar
I will now leave my basic troubleshooting skills and amateur advice behind and bow down to the RoverMasterTech.
All Hail!! All Hail!!
Old Mar 28, 2014 | 08:11 PM
Good. Scrub. You're obnoxious, sarcastic, and misinformed. Leave the advising to the pros.
eaglewing
Apr 16, 2011 11:06 AM
Snafu / Disco Fries
Feb 24, 2011 09:10 PM
lipadj46
Oct 17, 2010 06:34 PM
tito5590805
Oct 4, 2010 09:11 AM
DooDer
Jan 12, 2010 10:46 PM
