Oil pressure/temp gauge
Old Jul 13, 2012 | 11:18 AM
bballjames's Avatar
Default Oil pressure/temp gauge
Hey everyone. Looking at getting this set up...
Oil Filter Sender Adapter - 3/4 unf-16
Universal Dual Gauge Console Dash Pod
Tinted 7 Color Oil Pressure Gauge
Tinted 7 Color Oil Temperature Gauge
Has anyone done this set up? Has anyone mounted gauges to the dash? A-frame post?
Just looking for ideas for mounting. Pics would be great if you have them.
Looked over a couple older threads but couldn't find much on how people actually mounted these in their discos...
Thanks
Old Jul 13, 2012 | 12:32 PM
oilspotLR's Avatar
Thanks
I did this exact set up. Do you have additional fuse space in your fuse box or are you going to run a dedicated HOT wire from the engine bay? I ran them on a dedicated hot wire from the engine bay. I put a fuse on each line after I spliced it off the main hot wire. Then you have to run the sensor wire. I grounded them on the drivers side kick panel. I did this on the DI by the way. I put the oil psi on the left side of the main gauge cluster and the oil temp on the right side of the gauge cluster. I didn't want them together on one side because I didn't think it looked good. Plus both wouldn't fit on the left side of the gauge cluster. If you can find the piece that goes on the A pillar and fits correctly let me know.
Old Jul 13, 2012 | 12:43 PM
Bkreutz's Avatar
From the "must read" section at the top of D2 forum (this relates to water temp gauges but the mounting of the gauges and wiring would be similar)
https://landroverforums.com/forum/di...i-33833/page4/
Old Jul 13, 2012 | 12:53 PM
bballjames's Avatar
I will probably just run a hot wire straight from the engine bay, put a fuse on it and call it good.
I read somewhere that if you just buy a universal a pillar mount, you can heat it up with a blow dryer until it becomes pliable. Then mount it in the rover and screw it down flush. When it cools, it should be about the same shape as the a pillar and have a good snug fit. I haven't tried it though, so can't tell you much other than that.
@Bkreutz Thanks for the link. I remember seeing that a while back... not sure how I missed it in my search. I think I would like them mounted on the dash instead of the a pillar...
@oilspotLR I'm interested in where you mounted your gauges. Mind posting a pic that I can see? I like the sound of what you did...
Old Jul 13, 2012 | 01:04 PM
04duxlr's Avatar
Just build a custom gauge mount: Installed New Gauges - Land Rover Forums : Land Rover and Range Rover Forum
Old Jul 13, 2012 | 01:11 PM
bballjames's Avatar
Originally Posted by 04duxlr
Wow. Those are super clean. Might be a bit beyond my ability unfortunately...
Old Jul 13, 2012 | 01:55 PM
04duxlr's Avatar
No way - it was pretty easy! The texture of the bedliner paint I used covers just about anything so it doesn't require perfection. Of course, I used smaller diameter gauges but it should work for the bigger ones too. You might need to split them and put one on each side.
Old Jul 13, 2012 | 03:34 PM
oilspotLR's Avatar
Look at the pictures here:
https://landroverforums.com/forum/di...-instal-43603/
Tony Luna
Aug 21, 2015 08:56 AM
DustyLBottoms
Aug 6, 2015 08:39 PM
DustyLBottoms
Aug 6, 2015 01:49 PM
lipadj46
Oct 17, 2010 06:34 PM
lipadj46
Feb 16, 2010 05:20 PM
