Oil pressure wire
Old 04-23-2020 | 10:27 PM
redwhitekat's Avatar
Those pics are NOT in the RAVE " Workshop Manual " under ELECTRICAL.
They are in a separate section called " Electrical Library "
Most full versions of RAVE will have all the sections but....
You can see them under
> CONNECTOR
> CIRCUIT REFERENCE NUMBERS
HERE
>>> https://discoii.files.wordpress.com/...al-library.pdf
thanks found it and saved it. Explains a lot about the operation
Old 04-24-2020 | 10:13 AM
enb54's Avatar
Glad to see you solved your problem! As another useless fact, after helping a friend repair some Kenworth truck wiring, they use white wires as their grounding, something alien to most electricians. Ah well, live and learn...
landy_ala
06-16-2015 09:57 PM
schweiger
03-30-2013 03:53 PM
MrFlea1
01-30-2012 08:07 AM
smokey73
03-09-2010 09:14 PM
Quick Reply: Oil pressure wire
