OIL pump gear replacement?
Old 05-18-2015, 12:22 PM
abran's Avatar
Could I disconnect the inertia switch and crank it over?
Old 05-18-2015, 01:55 PM
drowssap's Avatar
There should be a yellow relay under the hood with a pic of an engine on it iirc
Old 05-18-2015, 02:46 PM
abran's Avatar
Well, I have been cranking it over for what seams like minutes and the oil light is still on. Maybe the cam bearings have moved and are v\blocking an oil port.
I think I am going to do the job over again.
Old 05-20-2015, 09:51 AM
RANDY04D2's Avatar
How did you get the fan off? mine just spins. Clutch spins independent of nut/shaft. Belt wont hold fan enough to break nut/fan ?
Old 05-20-2015, 10:08 AM
abran's Avatar
I have a fan clutch tool.
Some people have had success tightening the tensioner pulley, then hit the wrench abruptly to release the nut.
Check Amazon for fan clutch tool, I have the craftsman one. Or local auto parts will rent you one.
Re did my work last night, putting on the pan this morning. The gear I bought did have the bevel.
Old 05-20-2015, 10:15 AM
RANDY04D2's Avatar
Yea I got the 2 tools. Put the one on the fan clutch does nothing as my clutch/fan spins freely while holding the nut.....Mabey my fan clutch is sheared inside? could you just freewheel your fan/clutch with everything hooked up? I CAN.. Its like I would need to hold the water pump shaft still while loosening nut. Thinking bigger strap wrench on pump pully after removing belt (again)....thanks for quick reply..
Old 05-20-2015, 10:19 AM
5kcstq's Avatar
The fan normally spins independent of the nut... that's how they're designed. You have to hold the pulley to undo the nut, not the fan clutch. An easy way to do it is hold the pulley by hand and hit the edge of the nut with an air chisel. Can also do like abran said and hit the end of the steel wrench on the nut with a hammer while the pulley and belt are still on. Sometimes that's enough to break it loose.
Hope that helps.
Old 05-20-2015, 01:38 PM
abran's Avatar
New timing cover with new oil pump gear installed. Car knocked at first start start up. Shut it down, started again. Knocking went away as well as oil light.
I have a slight tick now. I filled it with water for testing, will add coolant once it cools down and some lucas oil treatment.
Overall, pretty happy with the result. Plenty of power, etc. Going to take it to a master tech later today for his opinion.
Old 05-20-2015, 10:17 PM
lighting's Avatar
Don't disconnect the serpentine belt since this offer resistance by holding the pulley and preventing from spinning free, just stick the fan clutch wrench on the hex nut and whack it with a rubber mallet, it will come off
Old 05-21-2015, 06:07 AM
drowssap's Avatar
has anyone told him its a left hand nut yet?
94svt50
01-22-2012 09:07 PM
94svt50
01-06-2012 08:23 PM
94svt50
09-15-2011 09:14 PM
kpl1228
03-26-2011 06:19 PM
mwindth
12-21-2010 08:28 AM
Quick Reply: OIL pump gear replacement?
