Oil pump removal
The bolts Rover used in the cross bars are very mild steel and one (or more) always seems to snap off. Good tip is to replace those with Grade 8 bolts with bigger heads and Never-Seez the heck out of them when reinstalling. You can chisel out the captured nuts on the broken bolts and replace those with new nuts on the top side.
Man, I had such a problem with the cross bar bolts. There's zero logic to using an M8 fastener with an M6 head on it in this location. After snapping 6 of 8 on the front bar and spending 3 hours with a chisel and drill, and then snapping all 4 on one side of the rear bar, I used a speed wrench on the last bit then welded it back together to reinstall it. Rover "engineers" really blew it on that one.
I can't believe that oil pump built pressure. Didi you get a reading beforehand?
