Oil pump removal
Old May 7, 2020 | 08:20 AM
merebel's Avatar
Well oil in antifreeze in and started it up ran it for a few as I still have a few more things to finish up but wanted to get a the oil circulating and coolant to bleed a little.
have to say I think it sounded better too
Old May 8, 2020 | 08:53 AM
Fast951's Avatar
The bolts Rover used in the cross bars are very mild steel and one (or more) always seems to snap off. Good tip is to replace those with Grade 8 bolts with bigger heads and Never-Seez the heck out of them when reinstalling. You can chisel out the captured nuts on the broken bolts and replace those with new nuts on the top side.
Old May 8, 2020 | 11:22 AM
merebel's Avatar
that’s a good idea thanks
Old May 8, 2020 | 12:32 PM
ahab's Avatar
Man, I had such a problem with the cross bar bolts. There's zero logic to using an M8 fastener with an M6 head on it in this location. After snapping 6 of 8 on the front bar and spending 3 hours with a chisel and drill, and then snapping all 4 on one side of the rear bar, I used a speed wrench on the last bit then welded it back together to reinstall it. Rover "engineers" really blew it on that one.
I can't believe that oil pump built pressure. Didi you get a reading beforehand?
Old May 8, 2020 | 01:27 PM
merebel's Avatar
I don’t have a way to read it yet
will get an auto gauge here soon
Old May 9, 2020 | 07:58 AM
mollusc's Avatar
I have two D2's. Four crossbars. Eight bolts per crossbar.
Not a single bolt would come loose. I hate them.
Ended up grinding off the heads and welding up any gouges in the mounting pads. Definitely going to find better hardware when it comes to putting them back on.
Old May 10, 2020 | 12:06 PM
Fast951's Avatar
After the heads snap off you can use a punch or drift to slam the bolts through from the bottom side. In my experience this breaks the entire bolt loose and removes the captured nut from the top side as well clearing the way for a new bolt and nut.
jharv
Sep 28, 2017 06:24 PM
DiscoCam
Jun 24, 2016 12:03 PM
kenk
Oct 7, 2009 07:59 PM
Christian_X
Oct 27, 2008 05:54 PM
cbwhitley
May 29, 2007 06:44 PM
