Oil Shaft Seals
Old Sep 2, 2015 | 02:33 PM
Charlie_V's Avatar
Default Oil Shaft Seals
I try to be a good Disco II owner; I really do. I gave myself a migraine yesterday figuring out what bolts to get for the crossmembers, finding them in grade 8, and ordering them.
Today I am looking for axle shaft seals. I am replacing my hubs and while I have it open I want to do what I can. Here is a picture of the seal (in the middle) from my buddy's truck:
The part is #6 on this diagram.
Is it the same part for front and back? Here is a front one. AB has them, too, but I see nothing listed for the back. Any ideas? Are they the same front and back? I see a diagram for the back but it does not have any such oil seal. Is that possible?
THis is the seal that goes around the axle shaft
Old Sep 2, 2015 | 03:53 PM
OffroadFrance's Avatar
You are correct, no oil seal. It is sealed by #2 in the diagram an "O" ring. Id you have the RAVE go to the rear hub cross section where it's shown clearer . It's easier to fit than the front seals but requires some hub stripping. They tend to leak after about 10 years and 100K miles.
Old Sep 2, 2015 | 04:14 PM
Charlie_V's Avatar
Perfect; I wasn't missing anything then. Thanks, ORFRANCE!
Old Sep 2, 2015 | 10:57 PM
R0VERGUY's Avatar
O-Ring in back and seals up front. When I replaced my rear diff I had to pull the axles so I replaced the o-rings. They are only $0.95 so I ordered extra as spares.
With the front seals you will once again find a seal puller to be your best friend. If you haven't bought one yet Charlie you must enjoy spending extra time with your Disco
Old Sep 3, 2015 | 07:43 AM
Charlie_V's Avatar
Hahaha!!!! Yes I found one! No more screwdrivers
Thanks for responding, Roverguy.
fpdavis3
Mar 8, 2013 08:27 PM
bagocheetohs
Feb 22, 2013 01:55 PM
skeester
Dec 30, 2011 05:42 AM
jpscinc
Sep 2, 2011 10:15 AM
