One nugget for throttle body replacement....
Old Jun 18, 2012 | 10:13 PM
RANDY04D2's Avatar
Default One nugget for mass airflow sensor replacement..
Ordered a MAF sensor from auto zone for about $135 if i remember correctly. Said it fit my 04 disco hse7. The only part nbr they had. The body was actually bigger than mine by 5-6mm. I was able to take the sensor off new body and fit it to my old smaller body. Same part number for sensor itself. Has type of antitamper torx type screw, i was able to remove the 2 screws with a (15 ?) torx driver with lots of side pressure..Plug right in and fired right up. Saved $500 over dealer part....Hope this helps someone...Put the wrong thread starter for throttle body..dont know how to chang it...this was MAF.....
Old Jun 19, 2012 | 12:20 AM
Bkreutz's Avatar
You can buy those anti tamper torx bits from the tool trucks (not sure where else but that's where I got mine)
Old Jun 19, 2012 | 07:25 AM
You would be better off buying the correct MAF from British Parts of Utah for around $146 and having matching part numbers and no potential for other MAF related codes, right out of the box with after market or generic parts.
SenatorPerry
Jul 15, 2013 10:28 AM
matt3502
Oct 20, 2010 12:39 PM
2003landroverdiscovery
Jul 16, 2010 04:29 PM
Frank4
Nov 25, 2009 11:49 PM
Doss
Mar 26, 2006 06:00 PM
