one shot into swivel balls
Old Apr 30, 2008 | 09:19 PM
snorlax's Avatar
Default one shot into swivel *****
Putting one shot in. I turned the wheel all the way to one side and I can see past the housing. I see a bearing/axle(?) in there. Turning gives a lot more room for the grease to enter, but have never read to turn the wheels when adding oil/one shot. My question is whether the grease is for this bearing/axle(?) and whether turning the wheel is a proper method for filling?
Thank you.
1995 SE7 5 spd
Old May 1, 2008 | 03:56 PM
motormikeyman's Avatar
8th Gear
Default RE: one shot into swivel *****
Yes, turning the wheel allows easier grease entry. You are adding grease to lubricate the half shaft pivot, which is basically a CV joint without the rubber boot on it. I just use CV grease from the local autozone which seems to work fine and leaks less than the runny snot from Atlantic British.
Old May 1, 2008 | 06:03 PM
Dont use to much, it will blow out your axle seals.
Old May 1, 2008 | 07:13 PM
snorlax's Avatar
Is the LR one shot package the right amount for one side?
drowssap
Jun 1, 2012 09:03 AM
drowssap
Jun 1, 2012 07:22 AM
greg409
Aug 16, 2010 09:13 PM
kenk
Jun 9, 2010 11:10 AM
reflextuning
Sep 27, 2008 11:36 AM
