Swivel balls
Old Jun 1, 2012 | 06:39 AM
drowssap's Avatar
Default Swivel *****
because its friday and most Disco owner have more than one LR, I am going to throw this post up here. feel free to delete it.
Does any have experience with swivel *****? The reason I ask my RRC has a knock in the left front almost sounds like a broken shock.
The shock looks fine but I can see that the left swivel ball is leaking, the right is damp but the left is leaking. I guess my question is will a swivel ball make a knocking noise?
I have to replace the steering flex coupling this weekend, it must be ripped or mush I can feel the play in the shaft and there is some noise associated with that but this noise is deeper.
Old Jun 1, 2012 | 07:21 AM
antichrist's Avatar
Disco II's don't have swivel *****, as I'm sure you're aware, so probably it's better to post this in the RR section, or more appropriately, in the general section since a lot of Land Rover models have swivel *****.
To answer your question, no, they won't make any noise unless the axle u-joint is so broken that it's hitting the inside. However, a u-joint can make a clicking noise when approaching failure (very common with CV's). If all the lube has leaked out then the u-joint is going to fail before long.
Old Jun 1, 2012 | 07:51 AM
jafir's Avatar
How is the shock tower? It's pretty common for those to rust away. I've seen them completely detach and start knocking around.
Old Jun 1, 2012 | 09:03 AM
drowssap's Avatar
towers are fine I was hoping that was all it was, so i guess i can rule out swivel *****.
I will have to look deeper thanks for the ideas
drowssap
Jun 1, 2012 07:22 AM
greg409
Aug 16, 2010 09:13 PM
kenk
Jun 9, 2010 11:10 AM
reflextuning
Sep 27, 2008 11:36 AM
snorlax
May 1, 2008 07:13 PM
