Is this the original driveshaft?
Hey guys, new 2004 D2 owner here. I've just begun performing the full list of preventative maintenance services described in several of the threads on the forum. However I cannot tell whether it is running the original front shaft. If so, I would like to change it out immediately. I'm hoping one of the LR experts on here can tell from these pictures. Any help is greatly appreciated.
U have taken 3 pictures, but non shows the u-joints! Look at u joints to see if they have grease fitting on double u-joint side ( connects to t-case). Then it's been rebuilt, u r ok, otherwise looks stock to me, with that zerk replacement short screw that is on first picture (comes from factory that way)
If there isn't, 2 options, either buy a new driveshaft that has total of 5 grease fitting's (2 on diff, side & 3 on t-case side) or take original shaft to a driveline shop and have them replace th original u-jays and centering ball with greaseable ones,( 2nd choice will cost a little less but not a whole lot less.)
it looks like the flange yoke and the driveshaft yoke are not aligned (rotated due to play). If this is the case, its close to failure.
robert.juric
11-03-2022 07:08 PM
