Is this the original driveshaft?
Old Apr 29, 2015 | 08:55 PM
LA_Disco2's Avatar
Default Is this the original driveshaft?
Hey guys, new 2004 D2 owner here. I've just begun performing the full list of preventative maintenance services described in several of the threads on the forum. However I cannot tell whether it is running the original front shaft. If so, I would like to change it out immediately. I'm hoping one of the LR experts on here can tell from these pictures. Any help is greatly appreciated.
Old Apr 29, 2015 | 08:58 PM
LA_Disco2's Avatar
Another image
Old Apr 29, 2015 | 08:59 PM
LA_Disco2's Avatar
One more pic (sorry, can't figure out how to post more than one at a time from an iPad)
Old Apr 29, 2015 | 10:10 PM
Bom2oo2's Avatar
U have taken 3 pictures, but non shows the u-joints! Look at u joints to see if they have grease fitting on double u-joint side ( connects to t-case). Then it's been rebuilt, u r ok, otherwise looks stock to me, with that zerk replacement short screw that is on first picture (comes from factory that way)
Old Apr 29, 2015 | 10:32 PM
LA_Disco2's Avatar
Thanks for the help. I just crawled underneath the truck and there is a grease fitting on the front u-joint but not on the back end where it attaches to the transfer case. Here is a better picture of the rear. So I guess this is the factory time bomb shaft?
Old Apr 29, 2015 | 11:30 PM
Bom2oo2's Avatar
If there isn't, 2 options, either buy a new driveshaft that has total of 5 grease fitting's (2 on diff, side & 3 on t-case side) or take original shaft to a driveline shop and have them replace th original u-jays and centering ball with greaseable ones,( 2nd choice will cost a little less but not a whole lot less.)
Old Apr 30, 2015 | 06:34 AM
acamato's Avatar
it looks like the flange yoke and the driveshaft yoke are not aligned (rotated due to play). If this is the case, its close to failure.
robert.juric
Nov 3, 2022 06:08 PM
Darover
Nov 22, 2007 03:20 PM
ddugan
Aug 18, 2005 10:32 PM
brunettc
Audio/Visual Electronics
Aug 8, 2005 07:31 AM
bgsats
Feb 8, 2005 02:07 AM
