Our 2001 Project DII
Old Mar 28, 2016 | 08:04 PM
  #131
DiscoBuckeye's Avatar
Originally Posted by Charlie_V
I maintain that the downstream sensors just measure cat function. I ignore them.
That 6 misfire. You've changed plugs and wires, right? No vacuum leaks. Not losing coolant. You checked spark.
ARE you sure that speak plug is tight?
The only other things I can think of are the injector and compression. Very unlikely that a coil is the issue with just one cylinder acting up.
I just changed the plugs
I know I am going to up at 3AM wondering what a speak plug is.
Old Mar 28, 2016 | 09:26 PM
  #132
Charlie_V's Avatar
Hahahahahah. I could tell you but I'd have to kill you.
Old Mar 29, 2016 | 12:02 AM
  #133
LR03NJ's Avatar
I just googled it, its the plug connected by wire to the coil. A speak plug. LOL!
Old Mar 29, 2016 | 05:05 AM
  #134
That makes much more sense than it being related somehow to Siri
Old Apr 3, 2016 | 06:16 PM
  #135
Running better but still have the 5 & 6 miss(down from 10 codes). different coil but right next each other on the top of the coil. Correct? Makes me wonder if something chewed on the wires or boots right at the coil.
Old Apr 13, 2016 | 08:45 PM
  #136
Quick video update while I wait to do wires coils and valve cover gaskets. Anyone know what this ringing/clang noise is? Right about 19 seconds in is where it is most prevalent. I thought maybe an idler pulley.
Old Apr 14, 2016 | 01:35 AM
  #137
Charlie_V's Avatar
I can't hear any sound. That's probably my blackberry screwing me. But the engine LOOKS good!
Old Apr 14, 2016 | 07:28 AM
  #138
Well, find something you can hear with and get back to me. On the engine being clean, a friend here suggested brake clean for vacuum leak detection. I guess it cleans the engine too. Bonus!
Old Apr 14, 2016 | 08:09 PM
  #139
number9's Avatar
Didn't hear any strange sounds either, sounds like idle is high though.
Easiest way to check idlers/pulleys is to remove belt and rotate them by hand. Check for wobble, dragging and lack of lubrication. Tensioner, 2 idlers, alt, a/c clutch and water pump.
Old Apr 14, 2016 | 08:12 PM
  #140
It was a cold start. It comes down after 29 seconds
