Oxygen sensor D2 2003
Old Jul 28, 2017 | 04:58 PM
KingKoopa's Avatar
Originally Posted by BackInA88
They both look like the white piece from the sensor connector are stuck in both vehicle harness connectors.
The 6 white posts are the pieces that hold the crimp connectors in the O2 plug I believe.
Grab one of the 6 white plastic pieces with some needle nose and see if they pull out.
x2 ^^^ Correct. Just pull out the white spacers.
Old Jul 29, 2017 | 09:34 AM
gulfstream69xr7's Avatar
Both pictures look like the white piece from the sensor connector are stuck in both vehicle harness connectors.
This is why I come to this forum.
Grabbed a pair of needle nose this morning, white connector pulled right out, new oxygen sensor slipped right in. Done!
Thank you very much for the explanation and the answer. Saved me a ton of work and trouble.
Cheers!!
Cheers!!
Old Jul 29, 2017 | 10:25 AM
KingKoopa's Avatar
glad it was the simple fix lol
Old Jul 29, 2017 | 01:59 PM
Best4x4's Avatar
Also rule of thumb on Bosch Upstream/Downstream O2 connectors = Orange to Orange & Grey to Grey. Walker & Denso are grey regardless, but I've seen some people do some crazy stuff to O2 sensor wiring harnesses lol.
Old Jul 29, 2017 | 05:11 PM
number9's Avatar
I tried cheap Rock Auto sensors, and they were dead right out of the box.
Cheap connectors fell apart causing your grief? Were the cheap sensors causing problems or was this just prophylactic?
Old Jul 31, 2017 | 08:12 AM
Cheap sensors were dead right out of the box. The Rover could not even read them. Threw codes for both sensors. Swapped in the Bosch sensors and reset the codes, "service" light is out and no new codes. Interestingly enough, it took a good long drive to get the Rover to "see" the new sensors.
gulfstream69xr7
Jul 28, 2017 12:54 PM
klandrover
Apr 5, 2016 12:50 PM
xb70valkarye
Oct 21, 2009 05:26 PM
EATMAN
Nov 10, 2006 12:15 AM
xb70valkarye
Feb 8, 2006 01:52 PM
