P0301; Compression test results. HG and more?
Old Nov 20, 2017 | 02:42 PM
LandBeard's Avatar
Unhappy P0301; Compression test results. HG and more?
2000 Disco2 4.0 w/ 164,000 miles
Been posting a lot after I had misfires on cylinders 1,3,5,7 with sluggish acceleration/loss of power over 50MPH before the multiple misfires. Went in and removed upper intake and cleaned out all the gunk under the valve covers; while in there I rebuilt all injectors and installed new plugs, wires, and relocated new coil packs thanks to Gerry's Mod.
All but one code remained - P0301.
Compression tested this past weekend and this is what I got:
LH Bank:
#1 (90)
#3 (125-135)
#5 (135-140)
#7 (140-145)
RH Bank:
#2 (160)
#4 (150)
#6 (140-145)
#8 (145-150)
These numbers are all low with #1 being a OMGWTF
So, is it safe to assume I'll be asking for a HG from Santa or is there anything else I should be thinking about?
Compression test results (range)
Cylinder #1 lean
Old Nov 20, 2017 | 05:24 PM
LR03NJ's Avatar
Hoping thats just a bad valve. Could also be leaking head gasket. I just had some major problem with misfire found here
https://landroverforums.com/forum/di...episode-86311/
I dont like the look of that plug. Get a borescope and go from there.
Old Nov 20, 2017 | 06:42 PM
abran's Avatar
Do a leak down test on #1 to find the leak.
Old Nov 21, 2017 | 07:54 AM
Greg Vasileff's Avatar
I think your lean plug may help you out with finding where the issue lies, which to "me" would suggest a bad valve.
My compression #s are not as good as yours, and I also have #6 at 90. But I also have several low 100s. I was going through a lot of misfire codes on 2,4,6,8, and was coming to the conclusion that it had to do with the compression. But I found the cause was bad spark wires on 4 and 8. No more codes and it really runs well, even on those compression numbers.
I just bought a bio-scope for my cell phone for $35USD. I will do a look see into my cylinders to see if I can get some clues.
Just looked at your plug again. so, ..Haa, OR, that plug has been steamed cleaned due to coolant getting into that cyl.
Old Nov 21, 2017 | 09:04 AM
OffroadFrance's Avatar
X1 ........... that plug tells a story, mega lean burn, as already stated, probably a valve. A borescope is the initial option but it won't solve your problems only possibly tell you what might be wrong inside.
Check RAVE for the correct cylinder pressures albeit they may be down a bit but they should all be within 20 psi of each other.
Old Nov 22, 2017 | 06:05 PM
LandBeard's Avatar
Thanks everyone! I did perform a leak down test and the dye never changed color - stayed blue at start up and while at operating temp.
So when you say bad valve, what exactly should I be looking for and what would the corrective procedure be?
Old Nov 22, 2017 | 06:38 PM
abran's Avatar
Leak down test is different. You use shop Air to pressurize a cylinder while the valves are all closed. Then you can find where it’s escaping.
you tube leak down test and you will see
DiscoBuckeye
Nov 28, 2017 04:44 AM
Lisa Bunch
Oct 24, 2017 07:43 AM
bradman951
Apr 22, 2013 01:07 PM
twaszak
Nov 30, 2010 08:06 PM
btbaus
Jan 20, 2010 04:38 PM
