P0455 and gas caps
No labeling. So I will send you the VIN. Thank you.
The gas filler tube is usually the problem. I have seen many warp while hot but be coming fine during an evap test. Usually when the car would sit outside in the hot sun the issue would occur. Usually we put a gas cap and if that doesn't fix it, it needs a new filler hose.
actually somewhere in my notes from training there was supposed to be a cutoff vin for the issue but apparently not.
