p1173/0153 issues
Old May 23, 2023 | 08:29 AM
NVDiscovery's Avatar
Default p1173/0153 issues
I've had an intermittent issue with the above codes. I installed a new Walker Premium O2 sensor and everything worked fine for a few weeks, Now the codes are back. Truck runs fine except for the codes. Not finding any real insights from other posts so I thought that I'd ask in a new post.
Thank you.
Old May 23, 2023 | 05:25 PM
Extinct's Avatar
Start by posting up the exact explanation out of the Rave manual, we don't actually memorize the code meaning
Old May 24, 2023 | 12:49 PM
The 1173 is a lean condition and the 0153 is a slow responding upstream O2 sensor. My hunch is that its a ground/voltage issue but curious what others have seen.
Old May 24, 2023 | 07:21 PM
Extinct's Avatar
Start by swapping left and right and see if it follows the sensor, although it sounds like you have a vacuum leak on that side. What else was repaired recently?
Old May 25, 2023 | 01:54 PM
No other recent repairs. I've had 3 upstream O2 sensors so I doubt that the sensor is the issue.
Thanks for the suggestion about the vacuum leak. I'll focus there.
devr13sdiscovery1
Dec 15, 2019 05:36 PM
ellie
Aug 31, 2012 09:10 AM
Buzzwalburg
Apr 13, 2012 05:42 PM
DiscoIIBrandon
Nov 17, 2010 09:23 AM
Jull
Jan 8, 2009 04:26 PM
