Pass door wont lock/unlock
Old Dec 2, 2007 | 09:43 PM
ja00disco2's Avatar
Default Pass door wont lock/unlock
Hi guys, I have a problem with my passenger side door. It wont seem to lock/unlock with the key fob or the centralize switch. I hear something clicking but the only way I can open is by pulling the lever from the inside. Can anyone tell me whats wrong or have any suggestions on how to fix it. Thanks in advance.
Old Dec 3, 2007 | 10:05 AM
Darover's Avatar
Default RE: Pass door wont lock/unlock
I have the same problem with my rear driver's side door. It's most likely the door lock actuator.
You have to change the whole unit.
Old Dec 3, 2007 | 10:43 AM
I have a left rear door that is that way when it is cold, usually takes 2 or 3 tries then works fine for the rest of the day. When you can hear them but they just won't unlock, then it is time to replace the lock actuators, which you can buy used for around $50 instead of new thru the dealer
Old Dec 3, 2007 | 11:15 AM
armlock's Avatar
I have the same problem with a couple of my doors i can hear somthing click but it want open, I have had the door panel off but i was worried about taking the levers off the actuator is there a trick how do you get them back on when you replace the actuator?
Old Dec 3, 2007 | 11:31 PM
crownaviation's Avatar
ORIGINAL: Disco Mike
I have the same problem with my right rear. Heard somewhere you can use re-pack the actuator with a petroleum jelly (vaseline). That was the suggestion to prime my oil pump after the timing cover repair.
Guess Rovers like vaseline...the dealership always seems to be out!!!
Old Dec 4, 2007 | 10:54 AM
okdiscoguy's Avatar
ORIGINAL: crownaviation
[sm=roll.gif]Learn to bring your own next time. They let you use it...
Old Dec 5, 2007 | 02:10 AM
ja00disco2's Avatar
Thanks guys for all the feedbacks. I will try to search for a used part and replace it.
hacksaw830
Jul 5, 2015 04:02 PM
kpl1228
Aug 19, 2012 05:33 PM
richierichrover
May 27, 2009 09:42 PM
NWRover750
May 24, 2008 01:08 PM
charlottejohnston
Jan 22, 2008 07:18 PM
