Passenger doors not unlocking
Bought a 2001 disco, key fob buttons are bad.
Disco's drive side unlocks and locks car, but it will not lock or unlock the three passenger doors.
the rear door locks an unlocks when drivers does.
The key will set alarm when locking from the door.
Is there a Fuse or connection I need to check.
I have looked at other threads but not finding an answer.
Help needed
Help needed
This drives me crazy too lol mine is the driver door. Everything but that one locks with the fob. Sometimes it works, sometimes not
Here is what I know... it's not always the actuator. If you can lock/unlock it from the switch inside, it's definitely not the actuator. The lock would need adjusted a bit and it would work.
If they don't unlock at all, it's the actuator.
I just saw this post. I have the same issue with both front doors actuators.
I found this old write up (https://landroverforums.com/forum/di...-new-one-3375/)
But some of those links no longer works.
have you find any solutions?
meltdowndave
04-19-2008 09:50 PM
