Passenger front seat won't go back or forth....
Old Mar 4, 2012 | 08:59 PM
mx468's Avatar
Default Passenger front seat won't go back or forth....
Ok my front passenger seat wont move forward or backwards, it goes up and down and tilts forward and back, any ideas? Driver side works fine. The fuses look fine under the passenger seat. Also, the seat would'nt work at all if is was the fuses, right? I switched the drivers seat switch with the passenger side and the same thing, no front to back movement...hmmm???? Do you think the front to back motor could be blown?, if so, can I change it without taking out the front seat. Thanks!!!
Old Mar 5, 2012 | 04:46 AM
Seat removal not difficult. Note that D1 and D2 seats do not interchange. If motor can't be obtained, remove drive cable and turn with electric drill to comfortable spot and leave it. You can meter volts from the seat switch on red , and the green/yellow. See attached.
File Type: pdf
Old Apr 20, 2018 | 04:56 PM
Disco_Dion17's Avatar
Any suggestions on a place to get the motor from? Can't find it on any of my normal sights. Also, where is the drive cable and how do you remove it? (photo if possible?)
Old Apr 20, 2018 | 06:33 PM
LR03NJ's Avatar
Are you sure the motor is kaput? Have you tried switching the working switches around? Is your problem similar to the original poster?
Old Apr 20, 2018 | 06:42 PM
I am fairly certain its the motor. I have power to the wiring harness that plugs directly into the motor. I used a test light to make sure the switch worked by toggling it both directions. But when plugged in, the motor doesn't make a peep and the seat doesn't move. The motor seems like the only explanation.
Old Apr 20, 2018 | 06:45 PM
LR03NJ's Avatar
https://www.ebay.com/itm/Land-Rover-...laMH3W&vxp=mtr
Old Apr 20, 2018 | 06:47 PM
LR03NJ's Avatar
https://www.ebay.com/itm/Land-Rover-...VassWi&vxp=mtr
Old Sep 25, 2019 | 06:52 PM
Stryngs88's Avatar
4th Gear
Default Same issue
2000 discovery 2 150k. My power seats works but the back and forward motion isnt working. I can hear the motor trying to work for an instant whenever using the controls, but then stops. It seems like it is stuck. I've swapped the control board from passenger side and tried swapping relays. Fuses are all good. The position isnt bad, just an inconvenience. Any ideas? Should I try to manually move the seat and see if the motor becomes unstuck? How do I do that?
Old Sep 26, 2019 | 01:29 PM
Llamasayswhat's Avatar
@Stryngs88
Please stop resurrecting 7 year old threads. Create a new one with your relevant questions if you cannot locate the answer via search
KlamathMatt
Oct 9, 2019 03:59 PM
jekylczar
Nov 4, 2014 12:52 AM
gbob
Apr 13, 2014 08:22 PM
mx468
Jul 3, 2012 09:08 AM
Poisonego2010
Dec 11, 2010 06:16 PM
