Driver seat adjustment motor?
Old Oct 8, 2019 | 07:24 PM
KlamathMatt's Avatar
Default Driver seat adjustment motor?
Daughter learning to drive...she ajusted seat way up, then she moved it back and it just died, allowing me just enough space to get behind the wheel. Lumbar, tilt and back and forth all not working.
Fuses and relay seem okay. Swapped them out with passenger seat, which works. But no dice. Hard to get down there to inspect the wiring but didn't see anything obvious.
Which leads me to seat motor. Can this be replaced without taking the seat out? Are there two motors for both lumbar and back and forth? Because neither movement works.
Thought and suggestions - appreciated!
Matt
Old Oct 8, 2019 | 09:20 PM
Jason Feuerstein's Avatar
I would pull the switch and clean the contacts first. They have a tendency to go.
Old Oct 9, 2019 | 02:25 AM
JUKE179r's Avatar
This!
Here is a wiring schematic for the seats...https://landroverforums.com/forum/at...d2-rh-seat.pdf
Here is a great tutorial from @AK Rover of opening up the seat switch and cleaning for a Disco 1 but you can apply it to the Disco 2... https://landroverforums.com/forum/di...-repair-17768/
Old Oct 9, 2019 | 03:59 PM
Extinct's Avatar
4 bolts to get the seat out, lots of time something gets stuck in the tracks (coins ) and prevent movements. The seat motors have an internal thermal fuse that can fail permanently open, you can solder across it but not easily.
back9sunday
Jan 14, 2019 12:09 PM
KernowDiscovery
Mar 19, 2015 09:45 PM
gbob
Apr 13, 2014 08:22 PM
Tomzsix
Feb 24, 2014 10:49 PM
mx468
Jul 3, 2012 09:08 AM
