Phantom door unlocking!!
Old Sep 5, 2013 | 06:40 PM
  #21
floundering's Avatar
Page 22 of 126 in the circuits manual for the 2000 D2 (another manual for later D2) shows receiver, with two earth wires (black) going to header C0707 on pins 7 & 2. Page attached.
On the 2003 up schematic you are correct, no grounds at that point.
If receiver is going wonky that would be one thing. Once you get into swapping out electronic modules (like BCM) price jumps up quickly.
Guess it pays to look at the correct model year... I'm a moron!!
So disconnecting pins 7 and 2 from header 707 should deactivate the receiver?
Old Sep 5, 2013 | 06:45 PM
  #22
Yep. May be esier than getting into the head liner.
Old Sep 20, 2013 | 09:30 AM
  #23
So far I've removed/disconnected the following...
Alarm RF receiver
Door lock fuse, turn signal relays, fuse 14 (IDM)
Disconnected door lock actuators
Left above unhooked- Still have a click at the passenger fuse box.
ANY suggestions??
Old Oct 22, 2013 | 09:00 AM
  #24
Default Fixed!!!
Replaced BCU ECU and instrument cluster (all used) as a matched set. Alarm disarming/unlocking problem is resolved. Also, working again are power mirrors, moonroofs, wipers... sure I forgot something!
Thanks for all the help along the way.
Fast951
Mar 11, 2015 09:21 AM
yonatan
Mar 10, 2014 11:14 AM
Tim08
Mar 28, 2012 09:51 PM
jpscott1
Oct 11, 2010 06:52 PM
yourbr.com
Jun 8, 2010 09:00 PM
