Please help me identify this black tubing
Old Jan 24, 2017 | 07:53 PM
80's old school's Avatar
Default Please help me identify this black tubing
So I am changing the spark plug wires in my Discovery. I have removed the coil pack and see two black plastic tubing hoses.
One I identified as the transmission vent. I will have to repair this line because it got on something hot and completely melted it closed.
The tubing I am trying to identify is the small black tubing that goes up the firewall behind the AC lines and then loops back down. You can see it in the picture... what is this line?
BTW, the person who designed the coil pack location is sadistic!!
Attached Thumbnails Please help me identify this black tubing-loop-tubing.jpg   Please help me identify this black tubing-trans-tubing.png
Old Jan 24, 2017 | 08:10 PM
Default I think I figured it out...
Looks like another vent tube that comes from the back of the trans and loops up and back to an open end.
Looks like it is the blue tubing in the picture below.
Attached Thumbnails Please help me identify this black tubing-loop-vent-tube.png
Old Jan 24, 2017 | 08:32 PM
Best4x4's Avatar
Transmission & Transfer Case Vents
Old Jan 24, 2017 | 10:43 PM
mln01's Avatar
And there is a front differential vent in there somewhere also.
Old Jan 25, 2017 | 10:54 AM
Best4x4's Avatar
Front diff vent runs along behind the brake booster up against the bulkhead and stops right before the bulkhead goes back for the Transmission hump.
Old Jan 25, 2017 | 11:44 AM
OffroadFrance's Avatar
X1 ............. there are various vent tubes, some come up on the bulkhead firewall and others from the axles elsewhere. If you are seeing these tubes on the firewall they are usually the transfer box and the autobox vents.
Old Jan 26, 2017 | 05:25 PM
Thanks for all the replies! I repaired the broken / melted vent line and finished the Plug wire and sparkplug change.
Combined with the front O2 sensor replacement I did today, it is running much smoother!
Twins Disco
Oct 31, 2020 06:24 PM
akbarkhan
Aug 18, 2013 01:29 PM
Savannah Buzz
Jul 18, 2011 09:35 PM
slave600
Sep 23, 2008 08:23 PM
OlDood
Jul 13, 2007 12:24 PM
