Pouring antifreeze around water pump.
Old Dec 7, 2019 | 03:01 PM
Klaywill90's Avatar
Default Pouring antifreeze around water pump.
So I went to put antifreeze in while car is off and started pouring out somewhere around water pump. I thought it was a hose clamp but it wasnt. Any ideas? The temp gauge never went above half way. It didnt run funny, or idle funny. But it started smoking when I parked, opened the hood and antifreeze was sprayed every where and still half left in reservoir. But 25min later when I unscrewed the reservoir cap it started POURING out from somewhere.
Old Dec 7, 2019 | 06:49 PM
Red5's Avatar
Hard to tell, but looks like a bad 4-way connector. If it is, this should fix it.
https://carrs4x4.com/collections/new...be-by-carrs4x4
Old Dec 7, 2019 | 07:03 PM
cfz2882's Avatar
on mine,114,000,both the 4 way connector and the water pump shaft seal were leaking along with a couple other spots.Changing the water pump on a D2 is easy luckily
Old Dec 7, 2019 | 08:04 PM
Brandon318's Avatar
Looks like it's coming from north of the 4-way. Examine the hose clamps attaching to your thermostat. Best by far way to troubleshoot it so go to auto zone and rent a coolant pressure tester kit. Dead simple to use and you can simulate the engine being without it being on. Super easy to spot leaks.
Old Dec 8, 2019 | 06:35 AM
mln01's Avatar
Several years ago a friend of mine with an '04 DII had a really bad leak from the front cover gasket. It was just like you describe; coolant would flow out from that leak as fast as you could pour it in the reservoir. The mechanic who fixed it for him said he had never seen a leak that bad.
BS50MGSXR
Aug 10, 2021 01:07 AM
Kras1967
Dec 6, 2016 11:07 PM
clint70
Oct 22, 2015 09:08 PM
MC04DII
Jan 1, 2013 10:49 PM
Spencerfitch
Sep 5, 2010 10:46 AM
