Power Steering Pump
To bleed: With the engine at operating temperature, have an assistant turn the steering wheel from lock to lock repeatedly while you loosed the bleed screw at the top of the steering gear allowing air to escape. While doing this, make sure the reservoir remains filled and doesn't run dry, lest you have to do it all over again.
The bleed screw is on the top of the steering gearbox just to the side of the large nut in the center of the top of the gearbox.
johnnyjohnny
09-26-2019 09:37 PM
joshjellel
02-16-2015 10:53 AM
Sandman0306
12-15-2012 03:24 PM
losinov
03-21-2011 08:57 PM
