Power Steering Pump
Old Jun 15, 2010 | 09:31 PM
casanova00's Avatar
Default Power Steering Pump
I changed the power steering pump on my 1999 DII. I changed it bcuz the pulley popped out on the original one. The problem is that my steering wheel is very hard to turn. What's else can be the problem?
Old Jun 15, 2010 | 10:47 PM
lordmorpheus's Avatar
Do you have fluid movement in the reservoir with the engine running? Did you bleed the system of air after changing the pump?
Old Jun 16, 2010 | 07:59 AM
Did you bleed the air from the gear box and new pump? As already asked, do you have fluid swirling in the fluid botle, if no you either have a bad pump or air in the lines.
Old Jun 16, 2010 | 09:46 PM
casanova00's Avatar
No I havent bled the air from the gear box, who do I do I go about that? Thanks guys!
Old Jun 16, 2010 | 09:56 PM
To bleed: With the engine at operating temperature, have an assistant turn the steering wheel from lock to lock repeatedly while you loosed the bleed screw at the top of the steering gear allowing air to escape. While doing this, make sure the reservoir remains filled and doesn't run dry, lest you have to do it all over again.
The bleed screw is on the top of the steering gearbox just to the side of the large nut in the center of the top of the gearbox.
johnnyjohnny
Sep 26, 2019 09:37 PM
joshjellel
Feb 16, 2015 10:53 AM
Sandman0306
Dec 15, 2012 03:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
