Power Steering Pump
Old Feb 25, 2014 | 05:11 PM
Rover Nick's Avatar
Default Power Steering Pump
So, I just changed my power steering pump and all went well. Wasn't too bad of a job. The groan sound is completely gone, but it is still a little tight. I have flushed out the reservoir 3 times and refilled. I have turned the wheels back and forth numerous times. Any other advice?
2004 Land Rover Discovery II S
Old Feb 25, 2014 | 05:27 PM
Dan7's Avatar
What kind of fluid did you use?
Old Feb 25, 2014 | 06:06 PM
Rover Nick's Avatar
Prestone from AutoZone and then I added some Lucas to it as well
Old Feb 25, 2014 | 06:15 PM
Dan7's Avatar
I believe you need to drain and use synthetic or you'll ruin your new pump.
EDIT: Believe I was thinking of brake fluid as far as needing to be synthetic, however it is generally agreed that synthetic fluid should be used in the PS system as well....probably wont "ruin" your pump, but may shorten the life. See following thread:
https://landroverforums.com/forum/di...ntities-40014/
Old Feb 25, 2014 | 08:03 PM
04duxlr's Avatar
There are plenty of ps pumps running plain ps fluid. ATF works also. Keeping it clean is key.
Old Feb 25, 2014 | 08:04 PM
Rover Nick's Avatar
i was thinking as long I keep it clean that it would be fine. What about the tightness? Will that work out over time?
Old Feb 25, 2014 | 08:08 PM
04duxlr's Avatar
Not sure about the tightness. Did you try bleeding the steering box using the nipple on top of it? How many miles on the truck? Are all of the steering components in good shape?
johnnyjohnny
Sep 26, 2019 09:37 PM
joshjellel
Feb 16, 2015 10:53 AM
Sandman0306
Dec 15, 2012 03:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
