Power Steering Pump
So, I just changed my power steering pump and all went well. Wasn't too bad of a job. The groan sound is completely gone, but it is still a little tight. I have flushed out the reservoir 3 times and refilled. I have turned the wheels back and forth numerous times. Any other advice?
2004 Land Rover Discovery II S
I believe you need to drain and use synthetic or you'll ruin your new pump.
EDIT: Believe I was thinking of brake fluid as far as needing to be synthetic, however it is generally agreed that synthetic fluid should be used in the PS system as well....probably wont "ruin" your pump, but may shorten the life. See following thread:
https://landroverforums.com/forum/di...ntities-40014/
johnnyjohnny
Sep 26, 2019 09:37 PM
joshjellel
Feb 16, 2015 10:53 AM
Sandman0306
Dec 15, 2012 03:24 PM
losinov
Mar 21, 2011 08:57 PM
