power steering trouble help
my wife drove the truck home from work with a "loud noise and hard steering " upon arrival it began to leak big time. The reservior is at minimum level. It looks like the leak is coming form the larger hose that connects under the box. Is my pump dead or is it air locked and i need to replace the hose. Disco Mike is you are reading can i give you a call your old number is out of service> thank you all--Caleb
bottom of pump
the hose that goes straight up and meets the pump at its base is the location of the leak. it acually looks like it is leaking where two parts of the pumps joins eachother. But the hose looks good. If it is the hose it is possibly leaking from the clamp under pressure. Like i said i have only manuel steerring at this point.
If the pump is leaking between the halves,remove the pump. Spilt the front and back apart,remove whats left of the print-o-seal gasket,clean and sand the gasket surfaces,CLEAN the inside and outside of he pump with brake clean,dry, apply a thin layer of gray stiff RTV silicone to one pump halve,reassemble the pump using lock tight on the bolts.Let the pump set overnight,then reinstall.
losinov
03-21-2011 08:57 PM
jycsalas
04-17-2009 02:21 AM
