power steering trouble help
Old Nov 28, 2009 | 12:12 PM
caleb's Avatar
Default power steering trouble help
my wife drove the truck home from work with a "loud noise and hard steering " upon arrival it began to leak big time. The reservior is at minimum level. It looks like the leak is coming form the larger hose that connects under the box. Is my pump dead or is it air locked and i need to replace the hose. Disco Mike is you are reading can i give you a call your old number is out of service> thank you all--Caleb
Old Nov 28, 2009 | 12:39 PM
caleb's Avatar
Default found leak at the pump
the hose on the bottom of pump is leaking. I forgot to mention i have an 03 disco.
Old Nov 28, 2009 | 01:26 PM
troubled's Avatar
are you sure it is the hose, mind started leaking in the gasket between the two halves
Old Nov 28, 2009 | 01:53 PM
caleb's Avatar
Default seems to be where it connects to pump
i added lucas stop and leak and started up car. all manuel steering --is it the pump or the box
Old Nov 28, 2009 | 01:56 PM
XCELLER8's Avatar
I'm sure Mike will respond soon, but you still need to find out EXACTLY where it's leaking, the hose, the pump, or maybe a loose fitting. Best not to drive this untill it's fixed....dangerous for you and could make repairs worse.
Old Nov 28, 2009 | 02:53 PM
caleb's Avatar
Default bottom of pump
the hose that goes straight up and meets the pump at its base is the location of the leak. it acually looks like it is leaking where two parts of the pumps joins eachother. But the hose looks good. If it is the hose it is possibly leaking from the clamp under pressure. Like i said i have only manuel steerring at this point.
Old Nov 30, 2009 | 09:46 PM
xengineguy's Avatar
If the pump is leaking between the halves,remove the pump. Spilt the front and back apart,remove whats left of the print-o-seal gasket,clean and sand the gasket surfaces,CLEAN the inside and outside of he pump with brake clean,dry, apply a thin layer of gray stiff RTV silicone to one pump halve,reassemble the pump using lock tight on the bolts.Let the pump set overnight,then reinstall.
Matt_Attack352
Jan 13, 2014 09:55 AM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
brokendisco1
Jan 3, 2006 05:39 AM
