Powersteering leak
Powersteering pump went up and I replaced it and all associated hoses and o rings. The high pressure hose from the reservoir drops down and inserts next to a second hose that looks like it comes from the radiator. There is a bracket with a single 10 mm bolt holding these two hoses down. I have fluid leaking by these two hoses and the bracket. I’ve removed, cleaned and replaced the o rings each time. Making sure hoses are completely seated and bolt is tightened. Leak is slow but it empties the system when driving in about a month. Any suggestions? I’ll try and add pics
