pp disco I question on the oil
Old Sep 14, 2008 | 10:30 PM
theworks001's Avatar
Default pp disco I question on the oil
Would 10w30 valvoline conventional oil work for my disco with a mopar oil filter?? Or should I go synthetic?? I live in Norther California and the disco has 97k miles. Also is there a special way to do the oil change on a disco because in discoweb they said something about loosing the prime. Sorry if its a stupid question
thanks
Old Sep 14, 2008 | 10:38 PM
Disco2Guy's Avatar
Default RE: pp disco I question on the oil
Nothing special to it, you'll need to use a 1/2" driver on the drain plug and 6 qts. to fill up.
Old Sep 14, 2008 | 10:49 PM
llesra's Avatar
my overly simplified rover oil change procedure:
drain old oil
refit drain plug
add new oil
fill new oil filter with new oil
remove old oil filter
install new oil filter
oil is a very subjective topic. if you want to go to synthetic, go for it. if not, conventional will do just fine.
Old Sep 14, 2008 | 11:17 PM
thanks for all your help guys this is my first Disco
Old Sep 15, 2008 | 07:55 AM
Just make sure that you change the oil every 3,000 miles when you use convential oil. That oil is fine, you just need to change it more often.
Make sure that you use the same oil everytime you change it.
Echoman
Mar 12, 2014 03:16 PM
colin2496
Sep 11, 2011 09:50 PM
zhirkhan
Jul 1, 2011 08:06 PM
RoverR
Nov 8, 2010 01:03 PM
humroot
Jul 3, 2010 10:29 PM
