Preventative Shuttle Valve Seal Replacement
Falconworks recommends regularly replacing the seals in the modulator as a preventative measure. Has anyone followed this advice? Just wondering if it is necessary or not. So far I've had no modulator codes and I'd like to keep it that way if possible.
I replaced mine when I changed out the modulator. They do need replacing because when they were out brake fluid gets to the modulator and eats the wiring. At least that was my case. How often they should be replaced, I don't know, but it is not a cheap fix. And once you see how small the parts are you will be shocked.
bosshogt
02-02-2012 06:52 PM
aarongregor
11-14-2011 08:31 PM
