Preventative Shuttle Valve Seal Replacement
Old Feb 8, 2014 | 07:17 AM
04duxlr's Avatar
Default Preventative Shuttle Valve Seal Replacement
Falconworks recommends regularly replacing the seals in the modulator as a preventative measure. Has anyone followed this advice? Just wondering if it is necessary or not. So far I've had no modulator codes and I'd like to keep it that way if possible.
Old Feb 8, 2014 | 08:17 AM
ralphobell's Avatar
I replaced mine when I changed out the modulator. They do need replacing because when they were out brake fluid gets to the modulator and eats the wiring. At least that was my case. How often they should be replaced, I don't know, but it is not a cheap fix. And once you see how small the parts are you will be shocked.
Old Feb 8, 2014 | 09:43 AM
dr. mordo's Avatar
As I see it, it's $74 for a switch. The only site I found had seals for $44. I would say it's not worth the expense of the seals to save the switch.
Old Feb 8, 2014 | 10:05 AM
ralphobell's Avatar
If they are not leaking it would be preventative, in my case mine wear leaking so I replaced. $44 is steep for two small seals and 4 c clips. But in my opinion it will help extend the life of the switch you are replacing.
jrmdir
Apr 8, 2013 03:51 PM
bosshogt
Feb 2, 2012 06:52 PM
aarongregor
Nov 14, 2011 08:31 PM
tbesselman
Dec 14, 2010 08:02 AM
majrmike
Oct 9, 2007 03:13 PM
