Problems with heater
Old Dec 24, 2010 | 09:08 AM
thomlyons1's Avatar
3rd Gear
Default Problems with heater
I have a 2004 Discovery II HSE. Just last week I noticed a whining noise behind the passenger side dash, sounded like a belt slipping. At about the same time the heat stopped working when the truck was not moving. When the truck is moving it works like an inferno but as soon as the vehicle stops moving (stop light, etc.) it blows cold almost like it is venting from the outside. Not even sure where to start. Does anyone have any ideas?
Old Dec 24, 2010 | 09:31 AM
oysterhead's Avatar
Is the passenger floorboard wet? Do you smell coolant?
Old Dec 24, 2010 | 09:33 AM
You probably have 2 issues, a coolant leak and a blower motor problem.
As for the coolant issue, when was the last time you added or checked your coolant, when it was stone cold? Pretty common problem with a Rover, could be a minor leak or the dreaded blown head gasket.
Old Dec 24, 2010 | 09:50 AM
thomlyons1's Avatar
3rd Gear
I do smell coolant and will check the level. As far as the blower motor, is that behind the dash or accessible under the hood? Also, what would other symptoms be for the blown head gasket?
Old Dec 24, 2010 | 09:51 AM
Don't worry about the blower motor and don't even drive the truck till you find and fix the coolant leak or you could be in the market for a replacement mote before next year.
If you need help with this, send me your number and I'll call you.
Old Dec 24, 2010 | 10:21 AM
thomlyons1's Avatar
3rd Gear
Thanks Mike, I appreciate the help. Looks like I'll be heading to the garage.
Old Dec 24, 2010 | 01:03 PM
oysterhead's Avatar
Keep checking the floorboard for wetness.
tmckenz
Mar 3, 2019 01:42 PM
ls1morethanyou
Jan 12, 2017 10:21 AM
thoward
Jun 9, 2008 05:06 PM
monkey2727
Feb 16, 2008 11:02 AM
peypug006
Dec 12, 2007 04:57 PM
